what cleaner is best 4 spray guns?
Old May 1, 2006 | 09:19 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
after getting to know this gun i noticed that ,ther paint does not want to come out of the cup too well.i tried regular thinner.not good.
Old May 1, 2006 | 12:23 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Usually the thinner you mix with the paint is the recommended one. Regular paint thinner will just worsen things as you probably found out!
Old May 1, 2006 | 12:58 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
this was ready to spray.but you're rite it junk the gun all up!it was from wally world
Old May 1, 2006 | 11:44 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
You should use the bags that go in the cup. That will save you some mess. Otherwise I just run a cup full of thinner through it
Old May 4, 2006 | 06:40 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
check the little air valve on top of the cap....if that gets clogged....your ****ed it wont get any paint out since there is no air alowing hte paint to flow out of the cup....so its the suction keeping the paint in the cup...clear the valve or try to spray wiht the top of the cup off...if it sprays fine without the top...teh air valve is your problem...if it doesnt spray well with the top off...clean the gun...really good...
Old May 5, 2006 | 08:55 AM
bigmaciroc's Avatar
THERE called pps cups, but you still have to clean the gun body, at my work we use 100% virgine lacquer thinner to clean everything. work good for us. ps. dont spray anything that you dont have to go to a "piant supplier" to get. just my 2cents
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
zman1969
Oct 1, 2015 11:09 AM
dusterbd
Sep 29, 2015 08:40 AM
Marc Brown
Sep 28, 2015 01:40 PM
