spider webs in paint
Old May 1, 2006 | 11:15 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i painted my car and now there is 7 places where i got these little webs.b4 i painted it i wet sanded the whole car.then i washed ,and everything.so what went wrong guys?
Old May 1, 2006 | 01:44 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Im guessing it's in the plastic pieces....I was told that the cracks go alot deeper than you think and even with the use of various fillers they can still emerge again. I had a few spots on my bumpers that had spiderwebs, and just decided to replace them, rather than risk it.
that's been my experience/knowledge with them, but hopefully a painter will chime in as well
Old May 1, 2006 | 02:17 PM
forace87iroc-z's Avatar
Car: 1987 Iroc-Z
Transmission: auto w/ shift kit
where are spider webs?
First where are the webs and second did you wipe the car down with prep wash to get rid of all oils after u washed it just before painting it?
I agree with other post also, if it is in bumpers or ground f/x then the webs are deeper than you think and have to be really sanded or just replaced to be for sure.
Old May 1, 2006 | 02:36 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
no the plastic parts were fine.it's the quater panels that screwed me.
Old May 1, 2006 | 03:18 PM
Car: 1987 Iroc-Z
next?
is there or was there much bondo or fiberglass work done there? if there is much done and it was not allowed to dry long enough then it will crack as it dries under the new paint due to shrinking of the bondo or fiberglass.
also if you sprayed it really wet with a low temp reducer or medium reducer then the moisture out of that went into the repair work and now is dryin under paint and causing the spider like webbing.
Old May 1, 2006 | 05:13 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Maybe you put on to much paint at once? That happens to me if I put to much paint.....of course, i've only used spray can stuff for things but I imagine the same thing would happen when you use a gun right?
Old May 2, 2006 | 06:50 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
there is no bondo or fiberglass in my quarters.i probably didnt have the gun set right and sprayed too much at 1 time.
Old May 2, 2006 | 07:09 AM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
you didnt get enough of the clear off, and you based over it causing the paint to shrink and crack looking like leatheryish stuff. I see it all the time to people who dont sand enough of hte clear offf or dont prep the car right with right cleaners.
Old May 2, 2006 | 07:42 AM
B Rhodes's Avatar
Car: 91 B4C
any enamal or urethane clear is usually safe to spray over. I usually get spider webbing when I have sanded through the paint and hit some "other" primer that lifts when its sprayed with color. I always use a sealer before I paint color. It wont lift laquer type primers and helps the paint stick. Like a safety layer. If you sprayed too thick you might get runs or solvent popping pinholes in the paint but not usually spider webbing.
Old May 4, 2006 | 07:17 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i bet thats prob what happened,the part about sanding too much,and lifting the previous primer.
Old May 4, 2006 | 02:24 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
it was 2 things 1 older prime,1 too much paint out of gun. thanks 2 evry1 4 thier info.
Old May 4, 2006 | 06:37 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
it lifted on you....no way to fix that cept for a repaint...and when ur done sanding..use a waterborne primer to make sure it doesnt happen again....and ive never seen a part act like that when you throw too much paint on it...i paint every day all day at my shop...its ****ty prepwork that coused that lift...and thats that...it happens tho...no matter what once in a while it happens to me too...
F-body driver
Mar 6, 2023 11:44 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
vinny R
Convertibles
Sep 9, 2015 11:27 AM
