GFX need help!
Old May 1, 2006 | 12:29 PM
Monster Pinck's Avatar
Car: 1982 Z28 Camaro
Engine: 362
Transmission: th350
Axle/Gears: 10bolt 3.42s
GFX need help!
I have a set of 82 side gfx and a set of 86 side gfx. Are those the same, or did the side gfx change from 85-90 also? The reason I am asking is because one of the 86 sides is a little busted up because the repair shop accidentally rolled the car over it. I was going to get it repaired, but I figured if the 82 sides are similar I can just use one of those as a replacement. THANKS
- Adam
Old May 1, 2006 | 10:10 PM
Engine: 362
Transmission: th350
ttt
Old May 1, 2006 | 11:33 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I would have the repair shop fix or pay to have it fixed or buy a replacement if they ran over it!
Old May 2, 2006 | 04:19 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
heres the low down on GFX.
i asume you mean camaros by the way...
82-84 had smaller GFX
85-90 had bassicly the same GFX but wider (closer to the ground)
and 91-92 had aero GFX. they had air scoops in the side skirt and front piece on the sides.
so no you cant use the 82 gfx with the 86. but if a body shop rolled your car over your gfx they should replace it for you. at least, thats how i feel. if someone mucks with my car, they pay for it!
hope this helps.
Old May 2, 2006 | 06:43 AM
Engine: 362
Transmission: th350
thanks guys!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
snakeshooter
Sep 7, 2015 11:15 AM
LittleFranks
Aug 20, 2015 03:55 PM
