jegs seats anyone?
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
jegs seats anyone?
Has anyone bought and installed the leather-like race seats (not the APC ones) that Jeg's is selling? I think Summit also sells something similar to this as well.
If so, how have you liked them and MORE importantly, how did you mount them? I am wondering if they might be too wide for our cars. Thanks for any insights you might care to share.
Brad
Brad
No one has tried these? Guess I may end up being the first if my curiosity gets the best of me. Anyone? Anywhere?
Car: '91 TA vert
Engine: turboLSx
Originally posted by firebirdjosh
Damn those look good, do they get hot in the sun? I'm sick of my leather ones burning me.
iansane-- YES! Those are the kind. Evidently you have been successful at mounting them. Can you describe your install and how it went? I was not referring to the plastic seats with separate seat cover thing that 406maro was referring to, but exactly what you pictured there. They almost seem too wide to fit, but evidently you got them in there. Any insights you can share on mounting these, etc. would be appreciated!
Brad
Brad
Oh-- iansane.... forgot to ask... what are you doing for seatbelts? Without the bracket on the side of the seat to handle the shoulder belt, I would think you would have to install some sort of racing harness. If that is what you did, how did you mount the straps that go through the two holes at the top of the seat? It is evidently dangerous to mount them to the rear floor because of possible spinal compression in an accident. Any insights on that? Thanks!
Brad
Brad
Car: '91 TA vert
Engine: turboLSx
They are almost too wide to make fit well. If I hadn't gotten them so cheaply I wouldn't have bought them Last I saw they were priced at ~195/ea in summit? I payed about 80/ea. I bought them through schucks (an autoparts store, they don't have them in ohio). They were priced at a little over a hundred each and I bought them with my discount. I haven't put the passanger side in yet but will take some pictures when I do.
They come with sliders but no frame to mount the sliders to the car. It wasn't difficult to make an adapter though. I just bent up some 1 1/2" wide flat stock to get a somewhat flat base and then made a square to bollt the sliders to and for stability.
As for the seatbelts, I'm using simpson 4 pt harnesses which hold me in well. Although I don't like the unadjustability for passangers. All my friends know how to adjust them though which doesn't take much.
To mount the shoulder harnesses on my car I just bolt them to the rear passangers should belt retractor location. Although I have a vert and it's different for hard tops. There is still enough room in one ~2" spot to stick the stock style seatbelt female side between the console and the seat.
I do have the fourthgen console which I don't know if that makes a difference. I think it's a tad wider than the stock console.
HTH
HTH
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
They fit with the factory firebird console. I have both front seats in my car. I used the factory brackets on mine. Took them off factory seats, used the front hole, marked and drilled for the back holes, bolted them back up. They are a cheap option until I am ready to step up. They do sit a bit higher than I care for in this configuration.
-Schultzy
-Schultzy
Car: '91 TA vert
Engine: turboLSx
You've got 'em in your ride too? I figured since they weren't red....
Yeah, they are a bit taller than I wanted. When I test fitted them installed with the stock brackets I hit my head on the fabric top.
I still do if I spike/gel my hair.
I guess there's another thing you don't have to worry about Schultzy.
Car: 1988 Camaro
Not the summit/Jegs brand, but here's my sport style seats I got off ebay.
To fix the mounts, I took the sliders off these seats and my stock seats, made some "tabs" to bolt to these seats, then bolt my stock sliders to the tabs and bolt into car. For more info on how I did it search on here, I done a write up on the install after I put them in, and posted it on here with alot of pics.
Car: 1988 Camaro
Here's another shot..
BTW.. I'm useing stock seat belts. I just hang the shoulder belt over the top/side of seat shoulder booster.
I won't use any type of harness with out a roll bar seat cross bar. Just not safe to mount them anywhere other than a crossbar.
I'm in the middle of a roll cage install now, and after I get that in I'll go to a 5 point harness, with shoulder belts hooked to the cage's seat crossbar
Thanks for all the great info guys! I really appreciate it! Looks like this is do-able and I will be getting these seats right after I get the new engine this spring. Now I need to decide on a color. My interior is beige/tan with black console/dash, etc.. I am seriously thinking the black, but they offer a tan as well. Any opinions? The tan looks like it will almost match the stock color, so I may go that way so it fits well with the new carpet and stock back seats.
Night rider 327, thanks for the info on the seat belts. Guess I can just leave the stockers and drape them over the side of the seat... never thought of that! I'll be looking up your install info ASAP through the search feature.
Thanks again, I really appreciate the help.
Brad
Brad
Car: 1988 Camaro
Firebird1984... Your welcome.
mw66nova.... Mine weighs 31 lbs each ready to bolt in. That's useing the camaro seat tracks/sliders and my flat bar tabs to adapt the stock sliders to seats.
My stock camaro seats with sliders on them weighed 36 lbs each.
So 10 lbs weight savings for the set over the stock seats. Not alot but every little bit helps.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
they sell seats JUST like the black ones above at the checker here in town. The last time I checked they were only 139 a piece.
As far as the weight, I lifted one to get a guesstimate and they feel heavier than the stockers,hence the reason I didn`t buy them.
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I'll stick with my 4th gen ebony leathers.
Well if I could find a set of 3rd-4th gen seats in great condition for the price of what I can get these for, I'd be all over it. Right now I could stand a new pair of seats and for the moment these will do nicely and fit the current budget. I've seen these mounted in a 1967 Camaro that is owned by a coworker and they look and feel great when I sat in them. For the price it will be hard to beat these in my book. These do have the harness openings in them by the way although I don't think I will go that route.
Brad
Brad
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Originally posted by iansane
They are almost too wide to make fit well. If I hadn't gotten them so cheaply I wouldn't have bought them Last I saw they were priced at ~195/ea in summit? I payed about 80/ea. I bought them through schucks (an autoparts store, they don't have them in ohio). HTH
Car: '91 TA vert
Engine: turboLSx
Originally posted by Vaneat-91RS
Actually, I think they might have Schucks under either the Kragen or Checkers banner back east.
Autozone is nationwide though. Cheap crap as well.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Nope. Farthest I think CSK goes is Tex-***. California is ALL Kragen except for one Schucks store and most of the rest is checker.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Originally Posted by firebirdjosh
Heavier, smaller bolsters, and no harnes provisions?! Sign me up!
They are lighter, mine are at least 10lbs lighter.
The have much more support, esp. lateral, and you can fit a 5 point with them.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally Posted by iansane
I'm pretty sure it's SML-300. I can check and get a SKU tommorrow if you want.
Car: '91 TA vert
Engine: turboLSx
CSK only sells them in black. So you'd have to go through summit/jegs for gray. Where's the closest store to you? I could always find out their location number and just transfer some down there to them. And you could go pick them up.
A SKU is just a companies 7 digit "code" for a specific item.
Ah that sucks, my interior is all light grey so I'd want to do the seats in light grey, but jegs wants like $220 a piece for them. If they are cheap enough though I could swing the black. The closest CSK according to their website is in El Paso which is on the other side of Texas from Houston.
Iansane, I just noticed you paid $80 a piece, I would definately do black for that price. If you could see how much over a $100 they go for and if they ship to residential or business addresses. El Paso is way too far. Their website says they will ship to your house or whatever but they don't list the seats as available.
Car: '91 TA vert
Engine: turboLSx
http://www.partsamerica.com/ProductD...tnumber=SML300
There is a $20 per seat mail in rebate that I could scan or snailmail to you if you wanted.
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
MrPackstin
Oct 25, 2017 08:09 PM
