shift idicator.
Old May 13, 2006 | 05:37 PM
F&Ybodlover's Avatar
shift idicator.
My shift indicator is 1 gear off. N is OD and so on. It was like that when I bought the car last week, and after taking the console off.I lined up the shifter with the shift plate,and tried to see if there is something that stops it from sliding up, but couldn't find anything.Is there a piece that keeps it from moving?
Old May 13, 2006 | 06:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There is a adjustment on the cable that connects to the trans.Put the trans in N,loosen the nut,alighn the shifter to N,tighten the nut.This should help,if not then something else is wrong!maybe someone else has help after this.
Old Jun 24, 2006 | 11:25 PM
dunnin's Avatar
Car: 87 Bird
had the same problem but it was where the two pieces connected @ the tranny. PLASTIC??? Replaced and had to promise I would put a ground strap from housing to frame(who designed that crap?)There's an adjustment down there also...
Old Jun 25, 2006 | 01:15 PM
I fixed it a few days later, the indicatior lens was just stuck up a little higher than it should have been, once I took the lens off, and put it back in right, it lined up
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
