1982 recarro spec sheet??????
Hi there I just got my decals in from Phoenix Graphics for my 82 trans am recarro edition. My problem is that I thought Phoenix provided a spec sheet for the decals placement(exact measurments) which they do not. I was wondering if anyone knows where I can get the exact measurements for the decals?????
Any help would be grateful
BOB
BOB
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I've never seen any, and the shop manual doesn't provide exact decal placement either. You will just have to look at another TA or photos for reference. The only decal that might be tricky is the sail bird decal...all the others should be pretty easy. I have an '82 TA also...all you have is the stripes at the bottom, Trans Am decals which go right above the fender molding, hood bird, which goes in the lower center of the hood, and the sail birds which are more toward the front of the car than centered on the sail panel. Don't know if this helps at all, but just get some good photos to look at and you should be ok.
Car: 1983 Daytona Trans Am
Engine: LG4
Car: 1982 Recaro T/A
Engine: 305 w/Carter carb.
Transmission: TH-350
Axle/Gears: stock
