Door rattle
Old May 27, 2006 | 08:24 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Door rattle
I recently installed 2 new doors on my 85 Berli from an 89 IROC. I have the gaps, and the window seals perfectly alligned. However, when I close my driver door, I can push on it , and move it about a quarter of in inch in and out. I loosened the striker and pushed it as far in as it would go, it helped some but the problem still exists. It is just really annoying, because when I go over bumps, my door rattles in and out. Is there any way to adjust this?
Old May 27, 2006 | 08:58 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The striker should be adjusted to get the door flush with the quarter. There are two little rectangular rubber bumpers that mount above and below the striker that might be missing and causing your rattles.
Old May 27, 2006 | 11:52 PM
Toehead's Avatar
I just went out and checked... The door is flush with the quarter and the rubber bumpers are still there, although they aren't touching the inside of the body... My passenger door is fine. Very weird lol. Thanks, and keep em coming
Old May 28, 2006 | 05:14 PM
Toehead's Avatar
Figured it out. The little rubber wedge that mates witht the metal wedge was not making contact, due to excessive clearance. I looked at the old door which I had removed, and I saw that it had little plastic spacers under the rubber, wehreas my new door didnt. I took it and the spacers, and put it on the new door. Now there are no problems Thanks, hope someboldy finds this useful eventually
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jrdturbo
Mar 31, 2016 02:58 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
