Lower GM door hinges... 2 holes vs. 3?
Old May 30, 2006 | 08:48 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I just bought some new lower door hinges from GM, as my detent rollers were shot, and I see that there are only two bolt holes instead of three like my original hinges. I don't mind drilling a tapping a third one, but I was just curious why they only gave me two holes?
Old May 30, 2006 | 06:58 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
cause the third hole was drilled on a per car basis at the factory. it is the alighnment hole.
Old May 30, 2006 | 07:07 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Good luck on installing those bad boys, PM lonsal and he can put new deterrent rollers on your old hinges (much easier)
Old Jun 1, 2006 | 11:48 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
With a little patience the door can be aligned without drilling the 3rd hole in the replacement body side lower bracket. Bad upper hinge pin bushings usually affect and or accelerated wear of the lower. Replace the upper hinge pin / bushings while your at it. Lon sells a great repair kit. Top-DownSolutions.com
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
