Need advice on rust repair
Old Jun 1, 2006 | 02:39 PM
CDN_87IROC's Avatar
I cut out some rust I had on my front wheel wall.
Now I am wondering, do I cut a piece of replacement metal the same size and weld it in flush .... or cut a larger size and weld it underneath (behind) where it will be covered anyways by the plastic liner? I realize either way it is going to require some bondo work.
thanks in advance.
Attached Thumbnails Need advice on rust repair-img_0976.jpg   Need advice on rust repair-img_0975.jpg
Old Jun 1, 2006 | 02:46 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Weld it flush. You can keep the patch piece in place while you tack it by using a couple of strong magnets. Or, you can drill four small holes around the perimeter of the hole you cut, and then screw small pieces of sheetmetal to the underside of the hole from the top, with the pieces designed to hold the patch in place while you weld it. Afterwards, you'd just remove the sheetmetal screws and support tabs, and then weld up the holes from the screws.
Old Jun 2, 2006 | 05:28 PM
tagta189's Avatar
That looks like that infamous place where the washer tank sits and every time the local jiffy lube apes spill washer fluid under the tank when they overfill it and it just sits down there till it rusts a nice size hole.I've got the exact same thing.
Old Jun 2, 2006 | 06:38 PM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
i had that too, i welded a peace of metal in there i fiberglassed then painted it now you could never tell it was there.
Old Jun 3, 2006 | 12:19 AM
CDN_87IROC's Avatar
Unfortunately, I never noticed until I removed the windshield washer tank that GM put the screw to hold the fender liner right through the wheel wall into the tank. It was near the top so it only leaked when full but often enough to rust it through. I will have some after pics later this month.
Old Jul 26, 2006 | 08:05 AM
CDN_87IROC's Avatar
Finally some time to patch it up
Attached Thumbnails Need advice on rust repair-img_1532.jpg   Need advice on rust repair-img_1535.jpg
Old Jul 26, 2006 | 01:12 PM
tagta189's Avatar
Well done.Nice clean job.
Old Jul 26, 2006 | 02:03 PM
darrells3rdgen's Avatar
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
from what I can see in the pic's above looks like you have everything out of the engine bay.
I would go ahead and weld up any ruff looking factory seems and make it look real nice. would make ya proud everytime you pop the hood!
and don't put that factory washer bottle back.
Old Jul 26, 2006 | 08:24 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Nice job man. Sure wish it was that easy to do my quarter panel =(
Old Jul 27, 2006 | 03:03 AM
CDN_87IROC's Avatar
Agree, washer bottle not going back in (neither are the windshield wipers or motors). When completed it will only be driven on sunny days.
Old Sep 3, 2006 | 08:30 AM
CDN_87IROC's Avatar
Final look with paint ... well worth the time
Old Sep 3, 2006 | 10:36 AM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
Wow man, you can't even tell it was patched . You're more than welcome to come fix my quarter panels
Old Sep 3, 2006 | 01:31 PM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
weird, ive never seen rot there. also i worked at Jiffy Lube and never overfilled the washer tank. especially on a thirdgen. But nice work man! looks great!
Old Sep 3, 2006 | 11:27 PM
CDN_87IROC's Avatar
Poject '86 .. thanks for offer .. I grew up in Ontario but now living in California.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
m00n420
Sep 11, 2015 02:39 PM
Stryker412
Sep 7, 2015 09:11 AM
mrdevontay
Sep 2, 2015 08:04 PM
