hatch motor unit
Old Jun 2, 2006 | 04:09 PM
youngmiguel's Avatar
Car: Trans Am
Engine: 305 TBI
hatch motor unit
I was thinking bout building a whole new hatch motor unit. will this be to expensive than just trying to buy a used one cause i've seen some go for 175 or even 225. so whats the best option for me? or if there is any one with idea help me out.
Old Jun 2, 2006 | 04:40 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
What year is the car? Because different years had different motors, and some are harder to find than others. You can check out Top Down Solutions (a sponsor on this site) they have a pretty good selection of hatch motor parts.
Also, this has been brought up a million times before...
Old Jun 3, 2006 | 02:07 AM
MavViper's Avatar
Ya, this has been brought up plenty of times. There are a couple ways to go about it though. You could buy a whole new one, which will cost you quite a bit as you've seen. Or buy a junk one that doesn't work and rebuild it. If you can figure out what is wrong with it then replace it.
That's what I did with mine, my hatch pull down unit was gone and I got a freebie one and basically made one good one out of it.
Old Jun 3, 2006 | 10:02 AM
j dezzy's Avatar
Car: 87 TA
I just rebuilt mine the other day. The crappy plastic gear inside the equaly crappy housing cracked in half. I got some 3500 PSI plastic bonding epoxy from autozone and put everything back together. after 15 minutes the stuff was as hard a rock. Then I used parts from an old headlight motor to repair/replace some worn out connections in the motor itself. Works fine now. And in the end I only spent $5 on the epoxy and $10 on the headlight motor....A whole lot cheaper than paying $110 at autozone for a new one. Or $225 from Hawks.
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
355sbcTPI
Aug 19, 2015 04:38 PM
stalkier
Aug 13, 2015 12:59 PM
