can i replace hatch pull down with manual
Old Jun 7, 2006 | 11:23 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
just as the title said is it possible to replace electric pull down with a regular lock. if so where could i acquire a manual lock for it?
Old Jun 8, 2006 | 12:16 AM
LaxStreetRacer's Avatar
Car: 91 Z28
It's been a couple years since i did it so im kinda fuzy on what it entailed, but if your motor burned out and you dont want to replace it this might help. Remove the pulldown assembly and somehow or another you can get an electric drill onto the big screw part that pulls it down, screw it all the way down and reinstall it onto the car. I dont remeber if you have to take it all apart to get at it, but I think the whole job took me less than 1/2 hour. My electric pop still works fine, I just gotta slam the hatch down by hand rather than having it suck in by itself.
Old Jun 8, 2006 | 08:04 PM
j dezzy's Avatar
Car: 87 TA
My buddies camaro's pull down motor burnt out and the gear was cracked. he didn't want to buy a new one cause he didn't want to deal with it if it happened again. I took the motor off the latch portion then shut the hatch. I crawled inside the trunk compartment and pushed the latch up the guides until it locked to the hatch, then I marked the location with a marker, opened the hatch, and welded the latch in place on the guides. Best thing I could think of. You just want to make sure it's welded down far enough to keep it water tight but up enough that it latches easily. Hope this helps. Jamie
Old Jun 8, 2006 | 08:58 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
thanxs for the responses guys all great ideas i might give the welding thing a try. i think i saw someone suggest that before but i forgot about it thanxs again
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
