ttops installed
Car: '89 Firebird XS
Engine: 2.8l MPI
Transmission: auto 4 speed
ttops installed
i was wondering if anyone has ever switched from a hard top or a sunroof car to one with ttops like had the roof section cut out, im wondering if its hard to do, and how much it would cost to do and where would i take it to have it done.
Car: 91 formula
Transmission: t5
you want to have water in your car everytime it rains ? ..... i wish ihad a hard top.
anyways, of course it can be done, its all a matter of how much you want to spend
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Originally Posted by ontarioiroc
Hey, I converted my 90 to a ttop. I found a roof from a 1987 Iroc and cut my roof off and welded the new one on. See my sig for pics.
Mike
Mike
Car: 90 IROC-Z
Sorry, My sig isn't working, here's the link
1990 Chevrolet Camaro - Mike's Chevrolet "90 IROC Z"
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
i believe there is a member here that is doing the conversion now. Not sure, but I think it's in the fabrication board?
Engine: 3.4 / 5.0
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
IMO i think any time u cut a hole in ur roof its never like stock, even if u take it in somewhere, ttops r high maintaince, u can ask my friend. They will most likely leak, though i think they leaked when they were new, even sunroofs, but then again thats my opinion.
Btw heres a thread 4 ya.
https://www.thirdgen.org/forums/fabr...onversion.html
Engine: 2.8l MPI
well see the car i have has has this ugly ragtop thingy (like an old vw bug) and i want a different thingy, the sunroof has way to much noise from wind and such and it doesnt keep the heat in. so i have always loved ttops and wanted it, but i dont weld so i wount be able to do it. so would i just take it to a body shop?
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
first of all, if you cut up your roof you will lose strucural integrity. especially with t-tops. but if you really need them, they arent very high maintnence, takes about 1 minute to adjust them and no more leaks. ive had to do it with both my cars, and ever since i havent had any problems at all.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Not for nothing, but for what you would pay to have that done properly, you could probably buy a decent 3rd gen with factory t-tops in it and still have some gas money left over.
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
If your car has already been cut for a sunroof, installed T-tops may be more expensive than its worth. The center section was almost certainly cut when the sunroof was installed, and a new bar would have to be welded in. There are so many Third gens around, can't you just find one with factory T-tops and keep your hardtop as is??
Engine: 2.8l MPI
its not a hardtop as is, and ive put to much money in it go get enought back to buy a newone, and if i bought a new one id need a 2.8l one and i did the 3.4 swap
(needs to be a 2.8l for insurance purposes)
ambainb
Apr 25, 2016 09:21 PM
