18¢ window stops
Old Jun 14, 2006 | 11:52 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
18¢ window stops
I finally found a use for those old rubber sway bar end link bushings. I bought 1/4" bolt by 3/4" with matching washer and nut from home depot (cost 18 cents a set). Drilled a hole in the bushing and cleaned the hole in the window track.
Old Jun 14, 2006 | 12:50 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Nice job.... I've been procrastinating coming up with a solution to replace my missing stop. But that gives me an idea..... maybe I can use the shock bushings I just pulled off to do the same thing.
Old Jun 14, 2006 | 01:21 PM
Faded's Avatar
Car: '91 Firebird
Why would you want window stops?
Old Jun 14, 2006 | 01:28 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
to keep your window from bottoming out and falling towards the outside of the door and chipping the glass on the bolts that hold the outer window sweeps. ASk me how i know
Old Jun 14, 2006 | 11:09 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Yea, mine will go down so far that when you roll it up, it catches on that trim strip on the outside that prevents water running down into the door. Ideally, you want it to stop going down past the little pads that are on that window trim strip.
Old Jun 15, 2006 | 10:40 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
my passenger side window is doing something wrong and i think this might be it. the window has scratches on it from going up and down on the outside of the window i will post pics later. does anyone know why it is doing this?
Old Jun 15, 2006 | 12:37 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Maroon, are you familiar with how those window are aligned in there? If not, I'll give you an idea.... On the inside of the window, you have 2 metal pieces with felt pads on them that push out on the window. On the outside (built into the weatherstipping seal thingy that runs the lenthth of the door that keeps water from running down into the door itself), you have some pads that push in on the window and oppose the two inside metal ones. The window is sandwiched between these inside and outside alignment pads.
Possiblilites:
a) the felt may be worn off those outside pads (but I wouldn't think it would scratch the window itself, but who knows)
b) that outside window seal is attached to the door by many screws. I wonder if one or some could have backed out enough to scrape your window.
c) I have no clue whether or not something in the window mechanism itself could be scraping.
85 Jimmy
Sep 30, 2015 07:56 AM
Fronzizzle
Sep 8, 2015 12:10 PM
