power door lock actuater prob.
Old Jun 20, 2006 | 03:56 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
My door lock actuaters in both doors are acting up. At first it was the passenger side, now both. I've used new switchs that are on the doors but they wont lock or unlock, any ideas? The drivers side was working great 3 weeks ago. maybe alittle spray lube or is there a fuse that is tied into these things? Im clueless as to what to do with them. Manually they work tho-.
Old Jun 20, 2006 | 04:12 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Is it like there catching up? I have the same problem and havent really messed with it. Just make sure all the slides are lubed and in good conditon. You might even have weak/defective actuaters. Maybe even a voltage drop in the system. Make sure thay get a full 12v+
Old Jun 20, 2006 | 04:29 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
What vehicle?
Old Jun 20, 2006 | 11:45 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
i have the same problem in my 88 gta. sometimes my power door locks work, and other times they dont. i think it might just be dirt in the actuators? maybe it needs some WD-40?
Old Jun 21, 2006 | 12:26 AM
ricktaylor's Avatar
Car: 84z28
power door locks.
the car is an 84z .
Old Jun 21, 2006 | 12:54 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Mine had the same problem
Mine had the same problem. Replaced the motors still would not work.
Look at the bracket. The one that rivets to the door and found over time that it had spread apart. So the motor could not compensate. Took the bracket off (removed rivet) and squeezed the bracket open back together. Then riveted them backon the car. They work great now.
Old Jun 22, 2006 | 10:20 AM
ricktaylor's Avatar
Car: 84z28
bracket
Thanks for the heads-up on the bracket, will check it out this weekend for sure. Its well worth the investigation.
Old Jun 22, 2006 | 10:33 AM
On my '88 Vette there is a lock sw in each door and both would unlock but not lock.
After ordering new switches, I pulled out the driver's door sw to find the connector pins heavily corroded. After cleaning the pins and plugging in the old sw problem solved.
Try cleaning both the sw contacts and the connector pins before getting further into the mechanism.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
