Bumper Covers, Repair Advice needed
Old Jun 25, 2006 | 03:58 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I bought 1 Front Bumper Cover from Pick ur Parts and 1 rear bumper cover from Ecology, came out to 90$ dollars!!!! some bull **** and they werent even in perfect condition.. but the best ones I could find... anyway I started sanding and primering these covers and I got frusterated and used a power disc sander on both the bumper covers.. and yes I messed them up it got too hot and now I have small wavy grooves (Using this DISC SANDER )
Now I read the plastic repair topic but that isnt working out for me...Im planning to use this EPOXY material, has anyone made the mistake Iv'e done and tried fixing it with this epoxy material? and if so how well did the repair work ?
Old Jul 21, 2006 | 01:26 PM
knightrider2278's Avatar
Car: I have a 1987 firebird
Engine: it has a 7.5l 455 in it
Transmission: i have a turbo 400
Axle/Gears: im not sure their factory
ive used that paint stripper on mine and came out fine you just has to be careful and keep it moving.but if you already have grooves in your plastic depending on how deep they are just use filler primer or you can fill in the scratches with a thing called icing or they have special bondo for plastics you mix two things together it stinks like rotten ***,but it works really well
Vintageracer
Jan 10, 2020 05:33 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
