What is the best way to remove window adhesive
Old Jul 3, 2006 | 03:14 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I got a replacement deck lid for my car that has a massive bead of window adhesive on it right now where it meets the hatch glass. What is the best way to remove this adhesive? It is definately sticky and messy. So far I have been able to pull some of it off by pulling on it.
I'd just like to know if anyone has any "tricks of the trade" that may work.
Old Jul 3, 2006 | 03:23 PM
evil_dave's Avatar
Car: '89 Trans Am
Engine: LO3
Transmission: 700-R4
try a straight razor (like the blade from a box knife). If it goes onto the rear defroster, try hot water. That method always works for me!
Old Jul 3, 2006 | 04:41 PM
TKO500's Avatar
I did not clarify in my initial post. The bead of adhesive is on the underside of the decklid, not on the glass that I need to remove.
Any suggestions? I was wondering if there is something I could spray on it, like brake clean and rub it off with a rag. Or maybe I should just remove a majority of it and reseal it on the new decklid?
Old Jul 3, 2006 | 09:12 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
brake or carb cleaners work good on sticky substances but depends what it is even though it should work usually takes everything off anything.
Old Jul 3, 2006 | 09:14 PM
TKO500's Avatar
I ended up using a flat blade screw driver to take most of it off, just leaving a small coating on the decklid. Then I took a rag loaded up with brake clean and rubbed the rest off. Took about an hour to get it all clean.
Then I sanded, primed and painted the underside. It should be ready to go on the car this coming weekend.
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
3rdgenparts
Aug 8, 2015 07:09 PM
