Floor paint
Old Jul 13, 2006 | 10:41 AM
drag1LE's Avatar
Car: 1991 Camaro 1LE Z28
Engine: 6.0L
Axle/Gears: Ford 9" 4.33
Floor paint
Ok, so I've just finished caging my car, and I've decided to leave the carpet out. I had to clean up some rusty parts on the floor (where moisture had been trapped under the carpet), and now I'd like to repaint those areas to match the rest of the floor of the car. You know, that grayish color.
Have any of you repainted your floor to match the factory color of the floor?
What type/color of paint works best?
Old Jul 13, 2006 | 11:59 PM
Roc Me 2's Avatar
Car: 1989 Iroc
Engine: In the works!!!
Axle/Gears: 9-bolt, 3.73 gears
I am going to do the same thing with my car and I was just going to use black paint but I am putting carpet back in. You could use what ever color you wanted but you will probably have to paint the whole floor.
Old Jul 14, 2006 | 08:19 AM
drag1LE's Avatar
Engine: 6.0L
I don't plan on reapinting the entire floor, just looking for a close approximation of the existing floor color so my interior doesn't have that "calico" look.
Anyone?
Old Jul 18, 2006 | 02:25 PM
drag1LE's Avatar
Engine: 6.0L
Old Jul 18, 2006 | 02:37 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
use spray paint that is similar... It will work fine, it obviously doesnt have the UV protection of a real paint but since it is going on an ugly floor use cheap paint... and when you scratch it or something touch ups will be a breeze.
Use duplicolor cans from walmart
Old Jul 18, 2006 | 03:49 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
well my floorpan is red so Im going to have a tough time recommending a specific color
im going to guess your car is grey also, or are you saying your floorpan is just in primer?
Old Jul 19, 2006 | 07:01 AM
drag1LE's Avatar
Engine: 6.0L
Car's black, floorpan's gray.
Old Jul 19, 2006 | 07:21 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
you might want to look at rustoleum high performance enamel. Stuff is tougher than nails and is available in spray cans, quarts and gallons at Home Depot, Lowe's, etc.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Sep 14, 2015 07:16 PM
Stryker412
Sep 7, 2015 09:11 AM
mrdevontay
Sep 2, 2015 08:04 PM
