hood flaps
Old Jul 16, 2006 | 02:47 PM
d_dubdb3's Avatar
hood flaps
i have a 83 cross fire injection camaro. the car has a ram air system from the factory. it has two little flaps that are supposed to flip up to allow the ram air. does anyone know where i can get a new motor or something for it?
Old Jul 16, 2006 | 03:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider a .
JamesC
Old Jul 16, 2006 | 04:26 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
if i remember correctly, it's been a while since i've seen one. those are vacuum operated.
Old Feb 14, 2007 | 03:41 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
can I get something straightend out? Were some of these hoods electronically power and others vacuumed? because mines electronic but you're not the first to say they were run on vacuum. so whats the deal?
Old Feb 14, 2007 | 06:29 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
All the functional fiberglass hoods('82-'83 CFI cars are the only ones factory equipped with functional hoods)are electrically controlled.There's a solenoid in the air door assembly that opens the doors.It's actuated by the ECM,thru a signal from the TPS,at full throttle.But the system works only after the motor reaches normal operating temp and only when the trans is in gear.You can check the solenoid by running 12VDC to it to make sure it works.Mine had an intemittent problem that turned out to be a loose ground at the fender next to the hood hinge.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
