Dome light door switch
Old Jul 17, 2006 | 01:10 AM
Trixter's Avatar
OK, I an installing an NEW overhead console that is taking the place of the dome light. We are installing a web cam, new lights, and speaker/mike in the console. Now we want to hard wire it directly into the power of the car. Anyone know the wiring for an 84 firebird so we can remove the door switches so we have constant power?
Do we re wire after removal? Can we use the wires already there?
Any help here would be great.
Trixter
Old Jul 17, 2006 | 01:43 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
When I installed an overhead console in my '87 IROC, the existing dome light power was connected to the console, and the power switches in the console were used to control power at the console. Unless the amps draw of the new components is a lot higher, there should be no need to run additional wiring. If you need to bypass the door switches, any of the accessory "on" posts at the fuse panel should be sufficient.
BRoss99
Aug 10, 2025 05:08 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
Omega
Aug 10, 2015 12:46 PM
