Replacing Speedometer Cable
Old Jul 20, 2006 | 12:51 AM
mwright1129's Avatar
Car: 1988 Camaro IROC-Z
Engine: 5.7L 350 Small Block
Hi,
I'm sorry if this question was already posted. I searched but didnt find anything quite related. I bought an 88 Camaro and am having it shipped but due to some unexpected mishaps before shipping, the speedometer cable that was supposed to be replaced wasnt. I'll obviously need to replace this before driving it home. I would greatly appreciate any and all help for how to do this, (keeping in mind I'm at a shipping terminal, so I'll obviously be bringing some tools along for the ride )
Thanks!
Old Jul 20, 2006 | 01:10 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
you'll need the t-10 torx bit to take off the gauge cover, 10mm 1/4in drive (i found easiest) to take out the gauge cluster. you'll need the 7mm to pull the underdash panel. the 14mm (i believe, might want to bring the 13 and 15 also) to drop down the steering wheel to allow the guage cluster to be pulled out. then you'll have to reach your hand around the back of the cluster to push on the clip to release the cable from the cluster. as far as the cable on the transmission it just unscrews from it might need some pliers. And running the cable is no fun take someone with you so they can feed the cable in to the car so you can grab it from the inside.
I think it took me 1/2 hour to do mainly because i have big hands and struggled with the clip 10 minutes. I think that's about it.
Old Jul 20, 2006 | 01:23 AM
Ok, thank you! It wont be coming in for about 2 weeks or so, but I figured I would be prepared before hand.
Old Jul 20, 2006 | 03:43 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Its a 13mm. He's right though, should take about half hour .. nothing to it.
Old Jul 20, 2006 | 04:28 PM
Jekyll & Hyde's Avatar
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I just did this on Saturday, feel free to ask any questions and I will try to watch this post.
Frozer!!!
Jan 19, 2024 04:55 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
