rear hard storage lid installation ???
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I know you'll have to change your plastic trim panel behind the tail lights.There is a ledge on the the panel that the lid rest on.That your car wont have if the lid was not optioned.There are two studs per side welded to the sheet metal.That the door hinge bolts to.Then you have the lock.On the sheet metal behind the tail lights ther may or may not be two holes that the palstic lock catch bolts to(after you mount the plastic trim piece).
I installed one in my Formula, all I did was use 4 Large, but short, self tapping screws to mount the cover, after I fit it and marked the holes, I used a drill bit with Masking tape on it so it didn't go too deep.
You also will need the back panel as well, as they are specific to the covers, and the cover sits on a ledge with rubber bumpers, and has the hole for the latch assembly.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
i want to put one in my car, i have the cover & the rear panel but i don't have any of the hardware/brackets, is it still poosible???
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Aug 26, 2015 08:17 AM
