Paint Code Location
Old Aug 1, 2006 | 10:37 AM
3rdGenThrowdown's Avatar
Car: 1986 Camaro Sport Coupe-totaled :_(
Engine: LG4 V8 (alive! HAHAHA!)
Transmission: automatic 4(alive-ish I think)
Axle/Gears: 2.73, stock (dead, most likely)
Paint Code Location
Where can I find the paint code location on my '86 S/C? I've looked everywhere I would know, inc. the drivers door, under the hood, radiator mount (Haynes says that there should be a plate there, but there isn't ?
Old Aug 1, 2006 | 11:12 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Look under the center console lid or on the inside of the locking cover in the hatch area.
Old Aug 5, 2006 | 12:36 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
no trim body tag on the rad support top ?
wow thats not good
are there two rivet holes where it was ?
hmm
yeah the only other way to find out really is to look on the RPO sticker and uhmm other than that im unsure, hmm..
if you dont have the rpo sticker either then damn, thats some bad luck there, previous owners were probably morons
Old Aug 5, 2006 | 10:06 PM
CrazyHawaiian's Avatar
Car: too many ...
I've always got my color codes off the RPO sticker in the car, either under the lid of the center console or under the lid of the rear console (drivers side in rear hatch). Should be at the bottom of the RPO sticker under all the RPO's. Might also be on the sticker on the Drivers door by the latch. The code will say BCCC and then have a set of 4-6 numbers, stands for Base Coat Clear Coat. If you can't find the code on your car then next best thing is to get a picture taken and post it and ask other members here with the same factory color to check for their codes.
LittleFranks
Sep 17, 2015 12:22 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
Out-Cast
Aug 17, 2015 10:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
