Will 90-92 Ground fx fit on my 86 camaro?
Old Sep 17, 2006 | 08:08 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
I have been looking but havent found the answer. i like the scoops on the 90-92 ground fx but im not sure if they will bolt up front, sides, rear quarters? Thanks
Old Sep 19, 2006 | 12:39 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
The side effects will but I think youll need a 91-92 style front bumper cover to match up with the ground effects.
Old Sep 20, 2006 | 08:34 PM
Car: 89 Iroc
Engine: 5.7 TPI
sounds great thanks for the replay i didnt know if anyone was gonna have any info lol. so basicly get the whole front bumper andfront ground effects together and it should all bolt up and the side ones go right on? thanks alot!
Old Sep 20, 2006 | 08:39 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
i know on the 86-89 gta the camaro RS gnx did mount (by driling new holes) but you could see the holes in the fender where the stock one mounted I dont know if that would help well at least if you try it on a gta you know what will happen LOL
Old Sep 20, 2006 | 08:44 PM
Car: 89 Iroc
Engine: 5.7 TPI
whats gta? sorry i cant figure it out
Old Sep 21, 2006 | 07:35 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
GTA is a Firebird
Old Sep 21, 2006 | 08:12 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The nose is the same all you need is the lower spoiler. The 91-92 fenders have slots cut for the front spoiler. easy to add to the 85-90 fenders.
I have a 91 nose on my 90 with the 90 ground effect. it bolted right up, there the same for 85-92.
you will need the rear bumper from a 91-92 as they are different. The rest will bolt right up might have to drill a hole or two.
Old Sep 21, 2006 | 08:35 PM
Car: 89 Iroc
Engine: 5.7 TPI
Thanks For The Reply. So Basically All I Have To Do Is Take The Old Stuff Off And Put The New Stuff On And Everythints Enterchangeable?
Old Sep 22, 2006 | 08:30 AM
MaineIrocer's Avatar
Car: 1986 Iroc-Z
Transmission: Automatic
I had a set of the side GFX of a 91 camaro given to me the issue is that one of the sides is missing 3 or 4 of the tabs all of which are on the end....anyone have any ideas how I can modify it to get it to still go on my car.....I wil attach pictures later if you dont understand what I am saying....
Old Sep 23, 2006 | 10:04 AM
Car: 89 Iroc
Engine: 5.7 TPI
yea post a pic i havent actually seen what the tabs are yet maybe i can see what might be able to work. youll have to post you progress of installing them on your 86 right?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
matthew911
Aug 12, 2015 09:38 AM
Vintageracer
Aug 11, 2015 08:13 PM
squiggy2
Aug 9, 2015 09:30 PM
