89 trans am Front bumper
Old Oct 10, 2006 | 11:32 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
well the front bumper on my trans am is cracked, bent and squared off where the front lisence plate goes. I am going to replace it soon and was wondering if there are any tips on removing it, thanks
Old Oct 10, 2006 | 11:51 PM
Denial's Avatar
Car: 84' z28
Engine: Built 350 SB 4 Bolt, Bored .30 Over
pretty sure its just held on by rivet type things, your going to have to replace them when you take them off anyway so i dont really think their is any special technique to takeing it off
Old Oct 10, 2006 | 11:55 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
ok thanks, ill checkit out tomorrow, just wanted a little heads up
Old Oct 17, 2006 | 05:17 PM
TKR Performance's Avatar
Car: 1985 Pontiac Trans Am
Engine: 6.6 Liter 406 c.i.
Transmission: T-56 6 Speed/ McLeod Street Twin
Axle/Gears: 3.42 9 Bolt Posi w/ girdle
It's actually held on by 4 little 10mm nuts and bolts that hold it to the fender. If you have a trans am you're going to have to unbolt the body kit and the body kit support brackets too.
Old Oct 17, 2006 | 06:20 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
yea i knew there was more to it then the litte rivet things.... the only ones i found were underneath where the bumper comes up to the body. one last thing... do u have to take the black metal piece off that is attached to the bumper as well as the fender bolts?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
