rocker arms rusted out...
Old Oct 21, 2006 | 05:53 AM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
rocker panels rusted out...
I was looking under my car the other day to check out what kind of rust I had since I will be under coating it soon. I noticed that my rocker arms where rusted out. Has anyone here ever had this problem and knows how to fix it?
Old Oct 21, 2006 | 01:37 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
There rocker "panels", rocker arms are on your heads. And you need to replace the rocker or cut out the rusted area and patch it, its welded on., not an easy task, not for someone who doesn't know what there doing bodywork wise.
Old Oct 21, 2006 | 03:40 PM
Car: 91 Trans Am
Sorry, I knew something didnt sound right when I was typing. Is this a common problem to fix or do you think I will have problems finding a body shop that can fix the rocker panels?
Old Oct 23, 2006 | 12:22 PM
Engine: Mild 350
You shouldn't haev much problem finding a shop. Its a common rust place, and a commmon place to get damaged when in a side impact. Do be prepared for a bit of money tho. I believe generally a rocker panel calls for a bit of labor.
Old Oct 23, 2006 | 12:38 PM
Frank89IROC's Avatar
Here's what you can expect to pay for the rocker panels, click below:
1982-1997 Camaro/Firebird Rocker Panels
Old Oct 23, 2006 | 08:37 PM
Car: 91 Trans Am
Thanks for the info. I know my uncle does some body work so hopfully he can help me out. Maybe this will be cheaper then I thougth since there only $52 a piece from Hawks.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
