headlight motor problem
Old Nov 2, 2006 | 09:54 AM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
Here's the problem I'm having:
Parking lights on, pass headlight goes up.
Headlights on, drivers headlight may or may not go up.
Driving with the lights up and I hit a bump, drivers headlight falls.
Drivers headlight sometimes can be moved freely and won't stay up.
Drivers headlight motor keeps running after the headlight goes down.
From the symptoms I describe, is it probable that my bushings and / or gear in the drivers side motor need to be replaced? TIA
Old Nov 8, 2006 | 02:05 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
That sounds like the internals of the driver motor, I'd say junkyard a new one. it'll be much less work to just take out 3 screws and swap a motor then to rebuild the one u have
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
