Window Rattles
Old Nov 28, 2006 | 09:22 AM
kurupt209's Avatar
Car: 86' Iroc-Z
Engine: 305 tpi
Axle/Gears: 2.77s
Window Rattles
Why in the hell does my window rattleso much in my iroc can someone please tell me the cure to this annoying problem ?
Old Nov 28, 2006 | 11:50 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I just replaced my outer window sweeps in my 87. MAJOR difference in how the doors sound when I close them, how the windows roll up and down, and no wind noise or rattles. Took about an hour per side to install them. And check to see if the little rubber bump stop on the back window channel is still there. Both mine were gone and allowed the window to roll down too far and catch under the outer sweep and try to tear it off when I rolled the window up. I used small furniture bump stops to replace my old ones. Cost about $3 for them. Hardest part was drilling out the rivet to get the old stop backing plate off. I used 10x24 botton head allen bolts and nylock nuts to put the new stops on.
I got them from www.gmpartsdirect.com
1 "10124264 SEAL STRP 10.710IY13" 24.60
1 "10124265 SEAL STRP 10.710IY13" 24.60
Old Nov 28, 2006 | 12:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might find something in the following link that will be helpful:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Nov 29, 2006 | 07:12 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My windows rattled pretty bad when rolled down. I fixed them up like this:
https://www.thirdgen.org/forums/body...ow-rattle.html
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
