Block sand
Old Dec 15, 2006 | 09:00 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Block sand
Think I should block this out before the body shop seals it, or just let them block it after they seal/prime it ?
http://members.cisdi.com/~anesthes/projects/sanding/
-- Joe
Old Dec 15, 2006 | 09:44 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Myself I would primer/surfacer the car, or high build primer it (depending on who you are talking to) and then block it out.You would be suprised at what you may find.A good paint job takes alot of prep.
Old Dec 15, 2006 | 10:29 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
couldn't agree more. We restored a 56 Corvette at the shop back in september. We primed it (4 coats with high build) blocked it, primed if with four more coats, blocked it, and once again, primed it...and blocked it. Came out super slick....especially since it was going to be painted black
Old Dec 17, 2006 | 07:29 PM
Craig H.'s Avatar
Prepping takes up most of the time. Painting is the easy part. Get plenty of sand paper and good luck.
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Jul 23, 2018 08:47 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
RyanJB
Sep 14, 2015 03:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
