Rim Questions
Old Dec 27, 2006 | 04:41 PM
jjohnston's Avatar
Car: 91 Camaro RS
Rim Questions
Ok, I have a 91 Camaro RS. it had the 305 from the factory, and the 16" rims. The offset for the rims are different for the front rims, than the back rims. I found a set of rims on Ebay I like, they say they are for the 92 Iroc. but I asked the guy about the offset. he tells me the offset of his rims are 0 for all 4. I asked about the fact that the front and rear have different offsets, and he said that was true, but his rims are all the same, and work better than the factory ones... I believe the factory made the offset different for a reason, and am apprehensive about getting them. What do you all think? There nice rims. Below is a picture of the rims I am looking at. but I want to get your feedback as to the offset problem.
Old Dec 27, 2006 | 05:35 PM
1320-camaro-383's Avatar
Car: 91 camaro
Engine: 383 demon 750 rpm heads 150 shot no
Transmission: bto 700r4 stage 3
Axle/Gears: currie 9" 4:10 true track
I think you are takling about the back spacing.Your factory ones are front 4.5 rear are 5 1/8 if you have the factory steel 1/8 in spacers it makes them 5.25.The reason the rear have more backspacing is so they dont stick out of your wheelwells.I have 4.5 on front and back of mine with no problems,some people think it gives it a more agresive look.The wheels you are looking at are nice,I would go for it.
Old Dec 28, 2006 | 12:08 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
There is no drivability or fitment issue with having both front and rear rims with the same backspace. If you like them...get them and enjoy.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Djmathis123
Sep 29, 2015 01:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
