HOW DO I FIX THIS?
Old Dec 27, 2006 | 05:36 PM
B&WIROC's Avatar
HOW DO I FIX THIS?
alright so i've been told i can fix these fairly large cracks with bondo. the question is... will that actually work and if it will do i have to take all the paint off or can i just smooth it off and paint over it and make it a quick 20 mins job? got pictures of it don't worry.
http://www.cardomain.com/ride/2534224
the pictures are on the second page.
Old Dec 27, 2006 | 05:46 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
load the pic here, make it easy for us....
oh and without seing the pic... no such things as an easy 20 min job. unless you dont care if its done wrong.
jeff
Old Dec 27, 2006 | 05:51 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
there, looks like a bad bondo job. the best fix would be to replace that portion of the qtr panel
Old Dec 27, 2006 | 06:02 PM
B&WIROC's Avatar
i'm pretty sure that's not bondo... the swirl effect around it was me trying to get the dirt off. to me it kinda looks like the owner might have used a reproduction part or soemthing and its just somehow managed to split.
Old Dec 27, 2006 | 07:14 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
that's either body filler or the paint has shrunk (if that's a word)....
Old Dec 31, 2006 | 09:08 AM
JeffW's Avatar
Engine: 305 tpi LB9
yep thats a paint issue, not a repo part or anything like that, take a d/a and sand it all down and see whats under it, but be prepared to repaint as well, that looks like single stage paint which does tend to crack. its an fairly easy fix with the right equipment. if thats the only bad spot on the car take it in to a body shop for a quick fix shouldnt be more than a few hundered to redo that section and blend.
jeff
oh and your main question... do not p;ut bondy over that the crak will come right back, sand away.... see what is under it, i wold guess bad bondy or just bad paint prep. sould also be 1k filler under 2 k paint filler without hardener will done some funky things under 2k paint( base clear)
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
