how to take off gfx
Old Jan 11, 2007 | 11:35 PM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
how to take off gfx
I have a 92 bird with gfx and a deer hit me in the pass. door.
I got a new door without gfx and need to swap it from wrecked door.
How do i get the gfx off the door. Any screws or clips. what tools needed
Just wondering what to expect I would hate to break anything due to my ignorance
Old Jan 11, 2007 | 11:47 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I had a B**** hit me in my 86 TA, the door i replaced was the passenger side, the door i got was a camaro door in excellent shape for 50$, but it was a no GFX door, i had to pull the old ones off carefully due to the soft mounting material, i then measured the old doors holes and drilled them on the new door, i made the holes a little bit larger for a tiny bit of adjustment to get it right, i used newspaper to raise the new door to the correct height, once i found the right mounting level i tightened the hinges, be patient and it will go, my 86 has the removable vents so that i was able to get to the door bracket easily, but be careful for this too is not to be rough with.
Old Jan 12, 2007 | 12:05 AM
Gramps's Avatar
Car: 87 Camaro IROC
after you remove your inner door cover, at the bottom you will notice a bunch of nuts, remove those nuts (10mm socket or 7/16" i think...i forget, its been a while). you will need a socket and about a 6" or longer extention and a ratchet. and dont break the nuts either because you need them.
Old Jan 12, 2007 | 02:33 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Just to add to gramps, there are also two "stub" looking things at the front lower corner, AND, the rear lower corner. They look like a pyramid (i dont remember how they come off), but i basically took vice grips and wiggled them loose, and popped off with a screw driver.
For the bolts, i beleive they are 10mm, when u pull off the inner cover, you will notice there are little holes already made in the steel part of the door. Stick the DEEP 10mm socket in there with an extension and unscrew.
Do you need to swap the rocker too? Or you just wanna replace the door?
Old Jan 12, 2007 | 11:16 AM
Gramps's Avatar
Car: 87 Camaro IROC
oh ya forgot about those, treat them like a nut, find a socket to remove them. the reason they look funny is because they were going to be visible and GM couldnt have a standard nut and thread sticking out.
Old Jan 12, 2007 | 11:28 AM
redbird92''s Avatar
Car: 92' firebird
cool thanks for all your help and now i have an Idea on what to do. Sounds simple and time consuming. I will give it a try hopefully today since it is nice out.
Thanks to all you guys
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
snakeshooter
Sep 7, 2015 11:15 AM
LittleFranks
Aug 20, 2015 03:55 PM
