fiberglass hood
Old Jan 19, 2007 | 08:25 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
fiberglass hood
here is my dilema i am planning on getting a fiberglass ram air II hood for my 85 trans am but in the process i am losing the original hood off of my car so the hood will have to go on my car immediately. now the hood is primered but not painted i will not have the $$$ to paint the hood for a little while maybe a couple of months even. can anyone tell me how this will affect the hood as far as being outside in the elements since the car isnt garage kept. thanx vinnie
Old Jan 19, 2007 | 08:49 PM
zdc590's Avatar
Well, as far as i know (not too much) primer is mainly put on to ensure that the paint has a better surface to stick to so the paint doesnt flake off too soon. But i also think primer is put down first to protect the surface from things such as moisture. So (this is just an assumption here) im pretty sure if you drive with it just primed, not too much will happen, considering its there to protect the material in the first place. Then again im an ignorant kid, id wait for more people to help, just incase
Old Jan 19, 2007 | 08:53 PM
jay92,85,79's Avatar
Car: 85z28,
Should not do anything to the hood. I would not use any kind of wax or tire shine stuff on your wheels cuz if it gets on thehood could soak in. And could make for a hell of a time for the painter that does haveto paint it. Just remmber that primmer is porous
Old Jan 19, 2007 | 08:57 PM
Car: 85 trans am
Engine: 383 stroker
from what i understand primer is pourous so it actually takes the other layers of paint to actually seal the surface and to be fully protected so on a metal surface with just primer moisture can still get to the actual metal surface and rust underneath. being as though this is a fiberglass hood i have no idea how it would be affected if at all if its not sealed. will it warp is one of my questions. i have no isea how fragile these fiberglass hoods are and what kind of actual care do they need until they are fully painted.
thanx jay i was in the middle of typing when u replied.
Last edited by white85transam; Jan 19, 2007 at 08:59 PM. Reason: Automerged Doublepost
Old Jan 19, 2007 | 09:01 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
it shouldn't hurt the hood to run it with just the primer. the only problem you may have is it may have to be stripped down and reprimered in order tobe painted.
Old Jan 19, 2007 | 09:39 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i know a guy who has been running a primered fiberglass cowl for at least a year and a half.. should be fine.. you might wanna throw a few coats of primer on there just to make sure it doesnt peel or flake or anything.. if you have to, use spray paint.. i mean you can use spray paint for anything so why not a fiberglass hood??
Old Jan 20, 2007 | 08:49 AM
Car: 85 trans am
Engine: 383 stroker
yeah i was thinkng of puttin a couple of coats of white and a clear coat of spray paint just so it doesnt stick out so bad until i can get either the hood or the whole car painted. does this ok to everyone else????
Old Jan 20, 2007 | 01:36 PM
5678TA's Avatar
Car: 1984 Trans Am
that sounds pretty good.. i dont see why it would be a bad idea.. hell, my brother's truck has a spray painted hood.. just make sure to coat it evenly and take your time..
Old Jan 21, 2007 | 08:42 AM
Car: 85 trans am
Engine: 383 stroker
thanx everyone
Old Jan 21, 2007 | 11:41 PM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
you should be fine. any good painter will sand down the top layers of your "factory" hood primer anyways and spray his own primer on top of it to help his brand of paint adhere better.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
