t-top question which is better
Old Jan 22, 2007 | 12:41 AM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
which top is better lexan or glass?? I have lexan on my z and was thinking about putting glass on it istead but not sure if thats a good idea what does everyone think,,,,,,,thanks steve
Old Jan 22, 2007 | 01:00 AM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I swithced from lexan to glass because my lexan tops squeaked like crazy.
Lexan also gets all those nasty spiderweb cracks in them.
I vote for glass.
Old Jan 22, 2007 | 12:22 PM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
Glass by all means. I think they're a bit heavier but that's the only drawback.
Old Jan 22, 2007 | 09:39 PM
marroman's Avatar
Car: 1987 Z28 Camaro
Engine: 350 small-block
ya small wieght difference but who cares it looks great....less you drop one....
Old Jan 28, 2007 | 03:55 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
i have glass on my 91 but when your going down the road you can hear alot of air comming in. is this normal? yes they are locked. when i had the paint job done i had the guy replace all that weatherstripping around them. any suggestions?? thanks!
Old Jan 28, 2007 | 05:46 PM
cdoyle's Avatar
I have glass on my 84, but they have a lot of scratches on them. Is there any way to remove them? Or at least make them less noticeable?
Old Jan 28, 2007 | 06:38 PM
Pocket's Avatar
Car: 91 Trans Am
Lexan: Lighter, more prone to age/weathering, harder to find in good condition
Glass: Heavier, more resiliant, more common, more expensive
Air comming in means they are not sealed, adjust the t-top pin recievers and windows. If that doesnt work oil up or replace the seals
Repairing the scratches: Top glass side can be buffed out like a scratched windshield. Underside is just limo tint and very easy to scratch. Have it removed and replaced by a good tint shop. VERY good tint shops can fix small scratches
Old Jan 28, 2007 | 06:41 PM
cdoyle's Avatar
thanks,
Ya all my scratches are on the outside, all those years of sitting stuff on them while I worked on the car.
what's the best way to buff these out?
Old Jan 28, 2007 | 06:50 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Originally Posted by camarogirl18
i have glass on my 91 but when your going down the road you can hear alot of air comming in is this normal? any suggestions?? thanks!
No, if its doing that you should tightn them down over time they work them selfs loose. But back to topic I have glass t tops and I like them, I would go with glass.
Old Jan 28, 2007 | 07:34 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I tried putting a set of glass ones on my Lexan equipped car last summer, and when I tried to latch them they didn't fit right. Do I need to change out the pin receivers? I have an extra set that are supposedly for glass tops...
Old Jan 28, 2007 | 09:15 PM
North's Avatar
Car: 1986 Camaro Z28
Engine: 400 chevy small block
Transmission: 5spd
ya glass is the way to go... if you cant find any i know of some in decent shape at the salvage yard in my town that i could pick up for you.
Old Jan 28, 2007 | 10:46 PM
Gramps's Avatar
Car: 87 Camaro IROC
adjust your T-top pin recievers a bit so the T-top is snugged down tighter into the weather stripping. are you sure its not the door weather stripping? thers a bit of a gap there too at the back where the glass seals. mayb you need to adjust your window glass too???
Old Feb 4, 2007 | 09:09 PM
Engine: 283
yeah im sure its not the door weather stripping. how do i adjust the pin recievers???? do i take off the plastic & handle???
Old Feb 4, 2007 | 09:15 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Remove the a-pillar and rear plastic trim pieces that the t-top pins mount through. Once off you'll see two screws that can be loosened allwing you to turn the plate which positions the pin receiver lower, so it compresses the t-top seal more upon installation. As I recall you'll need to re-drill the mount for the screw that attaches the trim panels since that original screw hole will have moved when you rotated the piece.
Lon
Old Feb 4, 2007 | 10:09 PM
Pocket's Avatar
Car: 91 Trans Am
The A pillar and rear trim pieces mount directly to the adjustable recievers so you wont have to redrill the holes. The move accordingly as you adjust them
Old Jun 26, 2007 | 07:07 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: t-top question which is better
anyone know the weight difference between glass and lexan t-tops?
Old Jun 26, 2007 | 07:55 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
The hole for the t-top mount moves though so to line that up you have to move the screw hole. Glass weighs more, I don't have my lexan ones here. The glass ones are MUCH nicer looking. FYI, the term is crazing for the cracks in the plastic tops.
Old Jun 29, 2007 | 08:58 AM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Axle/Gears: 2.73--
How do you adjust the pin recievers and windows? umb question maybe im not seeing somehting.. i dont know. but mine need to be but i dont know whow to do it.. Mine dont sit tight in i can move them around. like wiggle them
Old Jun 29, 2007 | 08:43 PM
Pocket's Avatar
Car: 91 Trans Am
Take the t-top out and look at the holes where the pins go
The recievers are behind those pieces of trim
1 screw up front and a few plastic clips
2 screws in the rear one
Each reciever has 2 x 9/32" screws holding them in place, loosen these and move the reciever down slightly
Put the t-top back in and latch it
If it doesnt squish itself down into the seals (you will feel the small resistance) then adjust further
If it wont latch then you moved them down too far, move them back up some and try again
Once your t-tops are seated good then put your trim pieces back over the recievers
Now drive down the road and listen for noise around your windows, if none or you cant locate the whistle then try the water test to find where its loose
If your window doesnt whistle or leak then your done
If it does then take your door panel off
Note ALL of the small 10mm bolts that hold your window mechanics in place
Each of these adjust the window in a different direction, youll have to tinker with these for a while. Be careful and only move one at a time and only a small amount
Old Jul 5, 2007 | 10:58 PM
slomaro92's Avatar
Car: 87 Iroc-Z
Engine: 355 tpi
Transmission: t5 pro 5.0 short throw Centerforce
I like glass but when I installed them (with new weatherstripping) they leaked. I kept the lexan incase I go to the track the only reason I switched was my paint started to peel on them. My glass tops have a mirror like finish on the inside does anyone else have this?
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
