door ground effects
Car: 86 camaro sport coupe
Engine: 305 ci 4bbl
Axle/Gears: 2:73 open
door ground effects
i have a 1986 camaro base model, no ground effects. i had been broadsided by a grandmarquis, and now am painting the car. i have 91 rs aero ground effects to be put on, taking them off my 87 iroc parts car, and i notice the door has these, i guess you could call them brakcets or hangers, that the door ground effects hang on. i cannot figure out how to get them off, or do i even need them?
Car: 87 Camaro IROC
on the doors, there are like 5 nuts that you remove from the inside of the door, thats how its held on...iirc. perhaps you mean the effects below the doors that attach on the fenders??? pics???
Engine: 305 ci 4bbl
no, you got the right spot, the lower door. i already got off the rocker ones. do i have to remove the door panel to get at the bolts? i am wondering why i dint see them before
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
You have to remove the door panel and peel back the bottom of the water shield to get ot the bolts. There are holes in the inner door skin that you can put a deep-well socket and extension through to get the nuts off. Then, there are two "acorn" nuts; one at the very back and one at the very front, neither is behind the door panel. Remove all those and the piece should come off.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
