door and t-top weatherstrips
Old Feb 1, 2007 | 07:24 PM
fastbird89's Avatar
Hello all, I bought new seals for my bird and was hoping to get some ideas on installing the t-top seals without having leaks.
Mark
Old Feb 1, 2007 | 08:25 PM
Gramps's Avatar
Car: 87 Camaro IROC
https://www.thirdgen.org/ttopleakfix
read carefully and go crazy
Old Feb 1, 2007 | 08:51 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Hmmmm, i have reservations about using silicone. Not a fan, I have used 3M's autobody sealant. Now I can't say that has been the best b/c I have the same issue with the huge hole in the corner between the weatherstrip and A-pillar corner, if you will. Fiberglass or welding more metal in that area would be the best option! What a crappy design from the factory!
Old Feb 1, 2007 | 11:51 PM
Gramps's Avatar
Car: 87 Camaro IROC
no kidding, i had leaky ttops, i siliconed them down and it was good for me. but you do have to fill in that 1" gap by the roof pillars or itll leak there too. its a crappy design, but silicone is just a brand name, you can use calking, itll move better, itll dry and hold out water better, and itll allow you to remove your weather stripping again without destroying it.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
codeysabatini
Sep 20, 2015 11:36 AM
m00n420
Sep 11, 2015 02:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
