t bar question
Old Feb 7, 2007 | 01:35 PM
vujk's Avatar
Car: 82 recaro TA
Engine: 355
Transmission: borg t-10
Axle/Gears: 3:73
t bar question
I am looking for a t bar for my 82 TA. Some of the ones I see on ebay and hawks list the tbar as 85-92, while others on ebay list the part from 82-92. Are there different tbars for 82-84 models? Or is there just one part?
Old Feb 7, 2007 | 04:41 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
yes, there are two different bars, the 82-84 bars have a little more clearance in the center section to allow the t-top edge frames (these are seen on the front and rear edge of the t-top facing the windsheild and hatch) to nestle under the center bar.
in 1985, the t-tops were redesigned and no longer had the edge frames, and were thinner as a result, so they redesigned the t-top bar to allow a tighter fit with the new glass tops.
the bar will install on your car without problems, but I don't know if the tops will fit right, someone with a early car who's replaced there t bar will have to chime in and say if they do.
Old Feb 7, 2007 | 04:48 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
hmm. interesting topic. I've seen the weatherseals listed as 85-92 also. I have an 84 and would like to go with t-tops that don't have the edge trim on them. What do I have to do to make those t-tops seal well on my car? I've been running with later t-tops anyway, but i did have some leaks. I am redoing everything on the car, so I'll be purchasing new seals either way.
Old Feb 8, 2007 | 03:23 PM
vujk's Avatar
Car: 82 recaro TA
Engine: 355
Axle/Gears: 3:73
does anyone know where to purchase one for 82-84? Or am I going to have to change to newer style t-tops to get the t-bar to fit proper with the 85-92 part?
Old Sep 1, 2014 | 02:37 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: t bar question
I need a 82-84 ttops bar. Will the 85-92 design work?
Frozer!!!
Jan 19, 2024 04:55 PM
RedLeader289
Jan 22, 2016 03:05 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
redmaroz
Aug 16, 2015 11:40 PM
