How to take door off 1983 z28
Car: 1983 Camaro Z28
Engine: 305 V8
hey, im replacing the door lower door pins on my 1983 camaro, i have the bottom pins out, the top linkage is holding me, how do i remove the door form the car, thanks
I actually need to know this too, I have both top bolts out of the hinge and 2 out of the three bolts out of the bottom hinge.. but the last bolt is IMPOSSIBLE to get to.. I was told by someone else, to take the pin out instead of unbolting the hinges.. but I have no idea how.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The last bolt can be removed by removing the under fender plastic shroud, turn the wheel all the way to the right or left depending on what door you are removing, and remove the bolt with a 10mm box wrench from behind the fender.
