Spot welds
Old Mar 3, 2007 | 04:02 PM
bigpoppa08's Avatar
Car: 82 Camaro
Engine: 305 SBC Carburetor
Transmission: TH-350
Spot welds
im replacing the rear drivers side quarter panel so far its gone fine up till where the qp is attached to the inner wheel well where there spot welded together im replacing because it has sever rust and i need to know the easiest way to find the spotwelds so i can drill them out and replace my qp
Old Mar 6, 2007 | 03:20 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have to do the same exact thing on my 82 t/a as soon as i find a clean QP skin off a car
if anyone has one to cut off and sell or trade me for somethin let me know
when i do it i will get a spotweld drill bit and drill the spotwelds
its a special bit
works great
the last time i needed one i was given one from one of the local autobody repair shops since no stores here sell them, it was a pretty well used one but i only needed it to drill a few spot welds out
you need to find one to do it right
otherwise i dunno
you have pics of your QP repair ?
id love to see pics of where your cutting and how much of your QP skin youre replacing
heres my rusted driver side QP right now:
http://smg.photobucket.com/albums/v2...ns%20am%20ws7/
also what do you plan on using to smooth out the transition overlap between the replacement and factory original skins ?
good luck and thanks for anything
Old Mar 6, 2007 | 08:20 PM
wicked-irocz's Avatar
The easiest way to find the spot welds is to take a angle grinder with a wire wheel and go after the area where they should be as in the door jamb, by the tail lights and in the fender lip. You should be able to tell by where the small dent is where they are. You dont need a special bit, if you cant find one just use regular drill bits, work up to a size that cuts the weld good enough to pull it away. You dont need to drill all the way through though I have and havent. On my pickup it was about a 5/16" bit if I remember right.
Old Mar 6, 2007 | 08:29 PM
jay92,85,79's Avatar
Car: 85z28,
U can also use a grinder.(cutoff wheel)But just grind though the outer metal
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
aaron7
Sep 30, 2015 09:15 AM
