Rusted Holes...
Old Mar 3, 2007 | 04:28 PM
L.I.N.Y.92CAMARO's Avatar
Rusted Holes...
I pulled my interior to POR 15 the floor then dynomat it, so when i pulled the carpet i found a few hole's maybe a quarter in size on my floorboards. I would say there is prob. around 6 of them. 2 by the passengers toes, 2 under the rear seat, and 2 right around the drivers seat. whats the easiest way to fix these and are they weakening the strength of my car at all?
-Thanks
Old Mar 3, 2007 | 07:42 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
it depends on how you define "fix" i had a few holes and i ended up cutting out a square around them, getting a set of good floor boards from a firebird that my friend paul hueing cut in half... then just cut what i needed out and welded it in... if you don't have those kind of resources you could always pop rivet a patch in and POR 15 it when its done... though thats kinda the half assed fix...
Old Mar 7, 2007 | 05:26 PM
dtk132's Avatar
Car: 1986 Camaro
Engine: 350ci 5.7L
Transmission: T-5 Borg Warner
Axle/Gears: 10bolt/ 3.42
If there the size of a quater then id say get about 3 -4 inch size pieces of galvanized metal about 20 gauge and either weld it in... or if you dont have a welder, get a product called 5200 from 3M they have it in any home depot ( usually used on boats) but a great adhesive thats water proof and as strong as a weld. Put that on both the edge around the hole and the side of metal going to cover the hole, then pop rivet it in. This stuff takes about a week to fully dy tho, i think 2 days to touch.. but it works good.
Old Mar 7, 2007 | 06:14 PM
Thanks alot for your response's. The bigger of the holes I will cut out and weld new patch panels in, but the smaller ones i will use that 5200 product.
-Thanks
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
