door hing bushings
Old Mar 23, 2007 | 08:50 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
door hing bushings
im looking to replace my hing bushings in both the doors on my 91 ta. anyone know were i can get a good set at a good price??
Old Mar 23, 2007 | 09:08 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
Re: door hing bushings
make them or just go to the help section in autozone
Old Mar 23, 2007 | 09:17 PM
Stephen's Avatar
Car: 87 GTA
Autozone only has the lower pins, which is generally not the problem.
Top Down Solutions Deluxe kit has upper & lowers, greasable, and you can get the Spring Tool/
Old Mar 23, 2007 | 11:04 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The TDS 200370 hinge repair kit is $74 per door. Yes I recommend getting a GM door spring tool to remove and install the door detent spring.
Lon Salgren
Top-Down Solutions
Old Mar 25, 2007 | 01:00 PM
5speed's Avatar
Car: 86 IROC
Transmission: 5 speed
Axle/Gears: limited slip
Finally ordered your greasable kit for my passenger door Lon.
My drivers door is good but I plan on doing it down the road for the greasable factor!
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
