Low Tension Hood Springs
Old Mar 24, 2007 | 02:54 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Everyone,
I recently purchased an aftermarket fiberglass hood for my 89 Firebird Formula. I know I need to get low-tension hood springs to use with it. However, I am having trouble locating any for my year. Can anyone refer me to a site that sells them? I tried Jegs & Summit, but their spring years only go up to 1981.
Thanks!
Old Mar 24, 2007 | 05:33 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: Low Tension Hood Springs
Originally Posted by formula_novice
Hi Everyone,
Thanks!
Our cars use hood struts, not springs... you're looking at first/second gen parts.
Old Mar 24, 2007 | 05:36 PM
Oh (insert icon of my hand hitting my forehead)
This is probably another dumb question but... will the factory hood struts work ok with the fiberglass?
Thanks!
Old Mar 24, 2007 | 05:44 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Usually it's best to get the light duty struts, it could work for a while but it will be putting a lot of stress at the back of the hood. Maybe see if your hood manufacturer offers them or possibly advance auto or something. I couldn't find any on summit, but they do exist.
One other thought... some of the earlier thirdgens came with factory fiberglass hoods, so there should be factory replacement struts which would be perfect for your application.
Last edited by ChillPhatCat; Mar 24, 2007 at 05:48 PM. Reason: Automerged Doublepost
Old Mar 24, 2007 | 11:18 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Order a set of hood struts for a 82 Z28 camaro with a fiberglass hood. those came factory with the fiberglass hood like on my car. The other trick is you can use the ones for a metal hood but get used worn out ones. That's what I have on my car. It gets the job done. But mine happen to be a little to weak. Just need to get the ones for an 82. Would be better. Adam :-)
Old Mar 25, 2007 | 08:02 AM
I'll check into those 82 hood struts.
Thank you both for your input. It is very appreciated!
Old Mar 26, 2007 | 02:00 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Here is a part number for the Strong Arm fiberglass hood struts.
Strong Arm 4134
LIFT SUPPORT STRNG
I just got them for my Unlimited Cowl Hood.
Old Mar 26, 2007 | 03:36 PM
Thanks a million, crazynights! I've been searching the web since posting this looking for something that would work.
Old Mar 26, 2007 | 04:14 PM
crazynights,
Where did you order yours from?
Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 11, 2015 09:02 PM
