weather striping t-top
Old Mar 25, 2007 | 03:07 PM
shaolink9's Avatar
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
i have a small leak right over my passenger in the t-top that id like to fix.
i have seen weather stiping at autozone can i use that or am i stuck spending 200 bucks on a new kit? i also have a leak sealer i used on the leaks in my truck will that work ???
Old Mar 25, 2007 | 06:39 PM
Subnoizebro's Avatar
Car: 1987 Z28 Camaro
Transmission: 5speed
Axle/Gears: 3.08
Re: weather striping t-top
https://www.thirdgen.org/ttopleakfix
there ya go bro, i did that on the whole weather striping on the car and it works great. Good luck.
Old Mar 25, 2007 | 07:28 PM
dragonslayerrb3's Avatar
Car: 91 RS
Engine: 305 tbi
Transmission: T-5 5 speed
Axle/Gears: Stock
i have a 91 rs and it looks like the PO had put the t-tops in with something lying on top of the weatherstripping on mine.it had one spot the size of a pencil that it was not touching the t-tops.well i took some silicone and filled the hole to matchh the weatherstripping and let it dry before i put them back in and it fixed mine.but if its leaking under the weatherstripping then use the method explained before.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
z28venezuela
Oct 24, 2015 08:15 PM
3.8TransAM
Oct 1, 2015 07:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
