Hood pins?
Old Apr 1, 2007 | 11:05 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Hood pins?
I am buying a fiberglass hood and was wondering if I could use just hood pins to hold it closed and remove the factory installed latch for weight savings and to clean up the look under my hood? Would just the pins be strong enough to hold the hood down?
Old Apr 1, 2007 | 11:34 AM
Trans87AM's Avatar
Car: 1987 Trans Am
Engine: 350 tpi
Transmission: 700 r4
Re: Hood pins?
They should be but their is no backup safty with them and youl onlu save like 1lb id say just polish the old hood lach and reinstal it on the new hood and ust the pins for looks .
Old Apr 1, 2007 | 11:57 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: Hood pins?
Keep the safety latch in case the hood pins fail. You can get rid of the release cable assembly though- it's fairly common for them to become jammed anyway.
Old Apr 17, 2007 | 02:59 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Hood pins?
I installed a 4" cowl harwood bolt on hood. Used the stock latch and all.. On the top end of the drag strip (118 mph trap speed) I noticed the front corners was lifting up some
So I installed hood pins in the front.. Fixed that prob, no more lift.
Then got to thinking to save alittle weight I would pull the front latch, cable, etc off. Saved a few pounds and just the pins holds the front of hood down just as good as the pins and latch.
I don't have a "clean" picture to show you but here's one right after I drilled the holesin the fiberglass hood for the pins to fit through (so theres white dust everywhere)
http://rides.webshots.com/photo/1535...41290424EJYNVO
http://rides.webshots.com/photo/1535...41290424OjaJqj
http://rides.webshots.com/photo/1535...41290424lJiFJT
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
