rear hatch window tint removal
Car: 88 firebird formula
Engine: 305 tpi
Transmission: 700r4 with shift kit
Axle/Gears: 3.73 with eaton locking diff
i have a purple sticker type tint in my rear hatch and ive been trying to get it off and ive been having problems. what is the best way to make this tint and the sticky glue stuff, off of ur hatch?
Car: 1993 Ford Mustang GT
Engine: 5.0
Transmission: 5speed
Axle/Gears: hell if i know
Re: rear hatch window tint removal
first you gotta park your car in the sun on a warm/hot day. then spray ammonia onto the purple plastic. then cover the purple plastic with garbage bags while it's soaked with ammonia. then on the outside of the window spray water and stick on garbage bags there to attract more heat. after about 10-15 minutes use a razor blade and start peeling. but be super duper careful because if you cut into the defroster your screwed. it should come out in semi-big sheets. that's how it was when i took that crap off my mustang.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
But what a difference it makes in the visibility. I couldn’t see anything more than shadows before.
Polo Z03
Sep 10, 2015 06:43 PM
