Floor pan rust
Old Apr 24, 2007 | 08:21 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
Floor pan rust
I have a 1987 camaro , while changing out carpet I found some rust hole's under the drivers seat and a 4 inch round hole infront of the driver's side rear seat. The passenger side floor pan is in very good shape, just a little surface rust. What can I do to halt rust in it's track's ? I know welding a new drivers side floor pan in is the preferred way but have no access to a welder. Any other repair ideas? How much can I expect to pay to have patche's welded in? Any help will be very much appreciated.
Old Apr 24, 2007 | 08:36 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: Floor pan rust
If you have the tools, you can paint over the rust will some rust inhibitor and rivet in some sheet metal for a temporary fix, but in the long run, you'd need to get the rust cut out and have some sheet metal welded in it's place. And some rubberized undercoating would be a good idea, too.
Old Apr 24, 2007 | 10:15 PM
subliminal's Avatar
Re: Floor pan rust
Sand down all the surface rust, weld in patches for the holes. And POR-15 your whole floorpan.
skinny z
Oct 5, 2015 06:23 PM
3.8TransAM
Sep 17, 2015 02:16 PM
Lanz06
Sep 14, 2015 07:16 PM
mrdevontay
Sep 2, 2015 08:04 PM
