Hood length?
Old May 2, 2007 | 04:09 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Hood length?
Is there any difference between the length of the hood on an 85 Iroc compared to a 91 camaro RS?
Old May 2, 2007 | 06:08 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Hood length?
UMM NO!
Old May 2, 2007 | 06:26 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: Hood length?
82-92 All hoods are the same.
Old May 2, 2007 | 09:48 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
Re: Hood length?
Hmmm. I don't know about that. I'm NOT a thirdgen GOD, but.... My 87 IROC has an RPO code E72 and the hood overhangs the front latch by 2 inches. I don't know what it was called, but I think it's the IROC hood.
RPO code:
E72 : BODY LENGTH, INCR I8 INCH
The hood is a couple inches longer than the stockers. this isn't the best picture of my car, but it gives you an idea of the extended hood.
http://www.soloatlanta.com/images/ga...y/target0.html
i've seen it on other cars but I'm not sure what it is called.
Old May 2, 2007 | 11:12 PM
Car: 91 Camaro RS
Engine: Small Block
Re: Hood length?
you may be right? I've swapped a hood from an IROC to my 91 and it fit just fine. I dont know
Old May 4, 2007 | 04:32 PM
Gr89RS's Avatar
Car: '02 Z06
Re: Hood length?
RPO code:
Lol..that rpo was on my old 89 RS and it isn't a body length increase. Apparently some of the rpo's change over time and they don't results you get when decoding them now are not the same as what they once where. Your hood is simply misaligned and that is what that gap is..
All thirdgen camaro hoods are the same length.
Old May 4, 2007 | 05:48 PM
geehumshriber's Avatar
Re: Hood length?
False. Not all hoods are the same. I have an 87 IROC hood I just put on an 82 Berlinetta and we are about 3/4 of an inch short on the front. Time to bust out the putty!
Old May 4, 2007 | 06:30 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Re: Hood length?
I'll false you back! LOL, I've had an 84, 88, 90, and currently a glass 82 hood on my 92 and they all fit fine. IMO, It's all in the adjustment unless it's had work done to it.
Old May 4, 2007 | 10:59 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Re: Hood length?
put the 2 hoods right next to each other and take a picture. I also think that there are "longer" hoods, but I need proof to show people it is not alignment.
I have access to 3 hoods i'll take measurements, and let you know.
Brian
Old May 5, 2007 | 12:30 AM
CYARS92's Avatar
Re: Hood length?
Do you really think mfg's such as Goodmark, VFN, Glastek, etc make different sizes for different years? No, at any Super Chevy Show ,etc. if you purchase a cowl hood or whatever for a Thirdgen, they'll go to the truck and grab one marked "Camaro 82-92". That's not to say there aren't minor differences between Mfg's though as that's to be expected.
Old May 5, 2007 | 06:44 PM
Re: Hood length?
Brian
please do!I honestly don't believe there are diff. length hoods for 82-92 camaros or firebirds for that matter.Please show us the proof.
Old May 11, 2007 | 10:49 PM
Re: Hood length?
any measurements yet?
Old May 12, 2007 | 03:52 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Hood length?
The only reason for a different length would be a bad aftermarket replacement and there are pleanty of those.
Old May 12, 2007 | 04:34 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
Re: Hood length?
body style had some subtle changes in 84-85 maybe thats why its not right
jeff
Old May 14, 2007 | 09:27 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Hood length?
DING !!!
If somebody find "CONSISTENT" hoods for xx year that are ALL the same.
and Then diff. hoods for years xx that are longer then above said hoods. Id like to see that.
Ive got a Grant in my packet that says it wont happen.
Old May 15, 2007 | 05:35 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Hood length?
After noticing a plate stamped 10/98 under my hood, i guess its safe to say its an aftermarket hood.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
