SANDING THE PLASTIC PIECES
Old May 13, 2007 | 03:57 PM
PROPHET69's Avatar
Car: Modified 1985 Z28
Engine: 355 Carbureted
Transmission: TH350 Turbo
HEY PEEPS, I'm about done stripping the paint off of my car. Well, the steel panels anyway. Paint stripper rocks. Now my prob is, as for the plastic pieces, i feel hesitant to use stripper on that, yet, when I was sanding, I noticed that not only was I sanding the paint off, but also the plastic itself. How can i do a proper level job without ruining the plastic?
Old May 14, 2007 | 09:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: SANDING THE PLASTIC PIECES
Don't strip them. As long as the paint is adhering to the pieces, just sand them so that new paint will adhere. Paint chips and other issues can be feathered.
Old May 14, 2007 | 12:09 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
what grit are you using, sounds pretty agressive to me
Old May 15, 2007 | 09:56 AM
PROPHET69's Avatar
OK, thanks, that helped me a lot, I managed to strip most of it yesterday without damage anyways. I was using heavy grid paper at first...220. The reason i was using grit that was so low is because I have 6 coats of paint on the damn car that has paint chips here and there. Impossible to shave all that off using 320 grit. So most of the plastic at this point is bare and very smooth. Almost too smooth. But anyone know what is a good primer for this type of plastic?
Old May 20, 2007 | 05:44 PM
Ucantcme57's Avatar
They make a flexible primer, or is it an additive that makes the paint flexible, I can't remeber, but you need paint that is flexible..
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Saxondale
Sep 15, 2015 06:42 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
