T-top seals
Old Jun 8, 2007 | 08:26 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
T-top seals
I need t-top seals for my 83 Trans Am but I'm having a hard time finding them. They are expensive as hell when I do find them.
Anyway, does anyone know where I can get a COMPLETE seal kit. I need EVERYTHING. I need the body seals, the seals that go on the t-top along the window, the seal trim that surrounds the t-top glass, and the window sweeps, which is basically everything.
I have only found one place I can get most if not all of what I need. I'm not sure it has the window sweeps but what worries me more is that in the description it says the following:
Replace your T-Top weatherstrip with our reproduction kit. Installs exactly as original and will elimante rattles and noise caused by insufficient sealing. Will also keep rain and other related elements from seeping into the interior. This is the 2nd design style.
Will work for all 1982 1983 1984 1985 1986 1987 1988 1989 1990 1991 1992 models despite the slight differences.
This 8 piece kit contains all seals necessary to repair both LH and RH sides.
this description has me concerned that the seals wont be right for my car.
Old Jun 8, 2007 | 09:22 PM
spitstickler's Avatar
Car: 86 IROC (Red on Red)
Engine: 305 tpi
Re: T-top seals
http://www.soffseal.com/
Old Oct 18, 2009 | 06:32 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: T-top seals
any updates?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
