door skins
Old Jul 1, 2007 | 10:32 AM
RArnold's Avatar
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
door skins
anybody have any useful information on buying new door skins for my 84 camaro-----where to buy fro, where not to buy from,...any experience putting new skins on their doors ???? any threads buried in here some where????
Old Jul 1, 2007 | 11:10 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: door skins
Door skins are pretty easy to do. First, you'll have to take your door off. Then grind the outter edge of the skin off. Once you have done that, the skin should lift on (depending on make and model of car, there may be a few spots welds). Once you get the skin off, clean and grind any glue that might be left. Then, apply a layer of 3M Auto Mix Panel Bonding adhesive. Lay the skin back on the door frame. Now, you'll have to use a hammer (either a body hammer or a door skin hammer) to fold down the flange around the door frame. Use either a block of wood, a dolly, or a bead bag when tapping down the flange. The first time around, don't try to fold the skin all the way...if you do..your skin may end up crooked. So, go around the door maybe 3 times. Then fit the door to the car to make sure it fits. Thats usually the way i do them...I'm sure other people might do them a little different. As far as where to get the 82-92 Camaro skins...I don't really know..maybe The Paddock..
Old Jul 1, 2007 | 02:17 PM
RArnold's Avatar
Re: door skins
how about the window weaterstripping where the window goes down into the door....any ideas on where to get that ????
Old Jul 1, 2007 | 02:40 PM
83Chevy__Camaro's Avatar
Re: door skins
the outside strips on the door that sweeps the window are still availbile, the inside are not.
Old Jul 1, 2007 | 05:03 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
Re: door skins
Buy the outside from a dealer! I got a set from classic industries and am having a VERY hard time getting them to fit, now i have to drill holes into the door and they still don't look very good, im very disappointed, definitively go with GM
Old Jul 2, 2007 | 05:44 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: door skins
Outer window strips from dealer. Door skin good luck best bet is to buy another door.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
