Outer window felt questions
Old Jul 26, 2007 | 07:41 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
ok well i bought classic industries POS product and have since bought the GM ones but i need to know what size screw/bolt is suppose to be used? Its been a while since ive had them in and ive misplaced the old ones...thanks guys
Old Jul 27, 2007 | 05:43 AM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: Outer window felt questions
someone must know...
Old Jul 27, 2007 | 08:41 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
the small flat washer style philips screws that are use all over the car. I think. I have my car here at work, I can check after lunch and get back to you. I will not know size, but I can tell you what they look like. I am positive they don't have specific screws, they are used many other paces in the car too. Then you can reference them and pick some up on ebay or junkyard.
Old Jul 29, 2007 | 11:12 AM
Celticsfan's Avatar
Car: 1985 Trans Am
anyone else? I want to run to the hardware store but it closes in like an hour...!
Old Jul 29, 2007 | 11:31 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have one right here in hand, it is about 1/4" long, and has a 7mm hex head.
Old Jul 29, 2007 | 01:37 PM
Celticsfan's Avatar
Car: 1985 Trans Am
hex meaning like a bolt? i think i have the right ones then
Old Jul 29, 2007 | 04:45 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
They are a 7mm hex head like a bolt.
Old Jul 30, 2007 | 03:41 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Axle/Gears: 3.42 / 3.42
what may I ask was wrong with the classic industries one? I was thinking about getting them but now i'm wondering if I should!
Old Jul 30, 2007 | 04:49 PM
Celticsfan's Avatar
Car: 1985 Trans Am
i could not get them to fit correctly the holes were all off and they did not cover the top of the door suffiently, honestly go to GM have them order the outer for $60, and check the board for the piece with the inner, itll work much better, now i have to see if i can return them i will be VERY pissed off if i cant return them...
Old Jul 30, 2007 | 05:18 PM
bntyhntr00's Avatar
Car: 91 Z28
Engine: TPI 305
Axle/Gears: 10 BOLT POSI 3.83
I used to work at classic bitch enough you'll get them returned - lol
Old Aug 1, 2007 | 10:34 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
According to the parts catalog the door felt screws are M4.2X1.41(10 used)
pfsteichen
Feb 9, 2016 06:59 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
